another daft newbie question
Started by aqautarkus, October 21, 2006, 02:57:59 PM
aqautarkus
hi again, ive just built tim escobedos utility boost and im well impressed, thing is is there anything to make the drive a little smoother,and less fuzzy,instead of the transistor in the circuit, could i use a jrc 4558 chip,(got loads of them) if so, how would i go about wiring it in?like i say im a newbie and still learning as much as i can, cheers again
chris
Seljer
Nope, the Utility Boost is based around a transistor (either a BJT or a JFET), your JRC4558s are dual opams, an entirely different thing.  If you don't like the fuzzyness you could try chaning the values of some caps to take away a bit of the high end for a smoother sound (I think you could put a small capacitor across the 2 outer terminals of the volume pot)
This here axe is the original axe with which George Washington chopped down the cherry tree.
It's had three new handles and two new heads...
markm
jonathan perez
