MXR Dynacomp Compressor problem
Started by bent, October 23, 2006, 10:37:41 PM
bent
Hi, i build it, and when i fisrt play, the sound was like my speaker amp was broke (the smallest cord sound ok, but the biggest cord sound horrible, cracking), i unplug and look at it, and when i plug it back....no sound-nothing-nada....and i touch nothing....
here some reading:
from general guitar schematic
Q1: 2N5088
E:5.74
B:3.45
C:9.08
Q2: 2N5088
E:0
B:0
C:7.78
Q3: 2N5088
E:0
B:0
C:7.76
Q4: 2N5088
E:8.29
B:7.78
C:9.07
Q5: 2N5088
E:4.57
B:5.22
C:4.64
D1: 1N914
BLACK STRIPE SIDE:9.08
OTHER: 0
D2: 1N914
BLACK STRIPE SIDE:0
OTHER: 0
D3:1N914
BLACK STRIPE SIDE: 9.06
OTHER: 0
IC: CA3080E
PIN1: N/A
PIN2: 3.93
PIN3: 3.87
PIN4: GROUND
PIN5: 0.69
PIN6: 5.20
PIN7: 9.06
PIN8: N/A
ANY HELP WILL BE APPRECIATE....
THANK's
BENT
Long live the music.....
brett
Hi
Q1, Q2 and Q3 have problems.  The base of all NPN, negative gorund transistors should be 0.7 volts higher than the emitter (and that's a mighty hand rule).
Check the resistors attached from the base to ground, and base to V+.
post your results
Brett Robinson
bent
thank'S brett,
i'll will check that and give you some news...
thanks
bent
bent
i finally found that R13 is 56K, and futurlec send me 5k6 instead of 56k, and it was write 56K on the bag.....i found it with my meter....( i went trought all my stock resistor (from 10ohm to 4M3) to double check the value just in case)
switch it with a 56k and the problem is solved....yeah!!!!!!!
thank you very mutch brett....
bent
