HOW TO TIGHTENED WAH PEDAL ROCKER?
Started by mikeeboy, October 25, 2006, 09:38:56 PM
mikeeboy
Sir just a newbie just wanted to ask how may i tightened the rocker of my Vox wah pedal? its pretty loose i cant figure out how to do it my quick fix is putting rubber bands just to add some tension when i rock it forward.. any suggestions sirs thanks in advance
The Tone God
If you look at the hinge there is a metal strap that goes across it. This strap is held to the case through screws and bolts on the inside which maybe under the board. If you tighten the bolts the strap will be held tighter against the hinder thus more tension on the hinge.
Andrew
mikeeboy
thanks alot sir i will take a look as soon as i get home ;D this forum is way too cool good thing i had some background on electronics kudos to sir :icon_biggrin:
Darren N
The 'axle/pin' should rotate with the top half of the pedal and the 'brake/strap' holds the whole thing where you left it. If the 'axle/pin' in the hinge has worn loose from the top half of the pedal (it has knurled ends to keep it in place) then tightening the strap will not help you (and might make things worse). You will need to insert some kind of collar or somethin for it to bite into (maybe even plumbers tape?). I haven't found the right thing for this yet, and I no longer have the pedal that was like this, so I can't give you a definite solution.
