Which 14-pin opamp should I use?
Started by jakenold, November 04, 2006, 08:06:48 AM
MartyMart
I'm SO pleased that my initial "brain fart" was correct  :icon_mrgreen: :icon_mrgreen:
...... I'm learning "something" here then !
Marty.
Dirk_Hendrik
Quote from: Paul Perry (Frostwave) on November 04, 2006, 05:06:29 PM
The only way it is possible to actually burn a chip (to the extent that damage is visible) is by connecting one of its pins to the mains. It simply can't happen otherwise (a mere battery or plugpack hasn't enough power, in my experience).
So, there could be one or two other things damaged...... but I have seen a few things that have been struck in this way, and the chips usually act as fuses OK!!
I've seen quite some opamps and other chips going up in smoke with a tiny "pfwweeeet" like sound on a battery.....
More stuff, less fear, less  hassle and less censoring? How 'bout it??. To discuss what YOU want to discuss instead of what others decide for you. It's possible...
But not at diystompboxes.com...... regrettably
jakenold
Great, with the help of Markus (Kusi), I've identified the chip. Thanks for everyones input, this place is great!!!  :icon_biggrin:
