hookup wire
Started by jlullo, November 04, 2006, 05:54:08 PM
jlullo
hey guys.  what gauge wire would i use if i drilled my holes with a 1/32" bit?  I bought 20 gauge thinking it would be able to fit, but it was just a bit too big.
thanks
boogietube
24 Gauge hookup wire -Stranded.
Pedals Built- Morley ABC Box, Fultone A/B Box, DIY Stompboxes True Bypass box, GGG Drop in Wah, AMZ Mosfet Boost, ROG Flipster, ROG Tonemender, Tonepad Big Muff Pi.
On the bench:  Rebote 2.5,  Dr Boogie, TS808
jlullo
jlullo
what one would that be if i were to order it from smallbear?
http://www.smallbearelec.com/Categories.bok?category=Wire+And+Cable
would it be the military grade wire?
jlullo
or any other place you guys suggest buying?  i can't find that gauge at radio shack
boogietube
Wire, #24 Pre-Bond, 50 Ft. Spool
SKU: 0508
That's it!
Support Steve and the diy community!
I've heard that this wire is the best to use -using cheaper wire can cause problems like the insulator melting. I'm still using some cheap wire and the insulation is not good. I'll be buying from Steve at SmallBear when I need to re-stock.
