Sunburst finish enclosure painting rig
Started by Pushtone, November 05, 2006, 01:35:31 PM
Pushtone
Remember that poor boys sunburst finish tutorial from awhile back at
http://www.projectguitar.com/tut/burst.htm
Man, I loved that. I wanted to give it a try.
The tutorial alone had me close to buying a 300 dollar Warmoth body, just to try this technique.
But my will to save money was strong and I never did loosen up the purse.
Then it occurred to me to try the technique on a 1590BB stompbox.
Results were very encouraging on painting small white cardboard boxes a two color burst over white base.
I moved on to the lids.
Looks good but the push-pins where leaving a "footprint" shadow behind.
Could have been my spray technique. I'm very heavy handed with the can.
Also the cardboard I was using with the push pins would warp into
a C shape as the paint dried, making it a one-time use only mask.
I decided what would be best for me was to make a small sunburst painting rig just for 1590BB enclosures.
The rig would suspend the "mask" over the work so as not to touch the work-surface.
And it could be reused, even while wet with paint.
It's made from 1/2" dowel, and a sheet of 1/4" plywood.
I drilled holes in the ends of the dowels and screwed thru the 1/4" plywood sheet to attach them.
I used guitar strings to tie off between the four posts and the mask.
The mask is Masonite cut to the smallest mask size needed to paint the inner color ring.
I use masking tape to enlarge the mask for painting the outside color ring,
which should match the dimensions of the box top.
I painted two lids and two boxes. This one turned out the best.
I started with a white painted box. Used a soup can to hold the box.
Sprayed YELLOW inner ring using small mask.
Enlarged mask to full size with tape and sprayed ORANGE outer ring and sides.
I picked the colors with help from the Virtual Guitar Modeling System at
http://www.nymphusa.com/kisekae/kisekaeE1.asp
Darn this is hard and fun!
It will take some time and a few spray cans to get good at this. More than I have time for.
I hope some of you give this a try. I know there would be some excellent looking finishes.
Gilles C
Nice color and nice result.
But I think you're ready for an airbrush...  ;)
It would be easier to do.
Gilles
Peter Snowberg
Eschew paradigm obfuscation
Roobin
Man, that's amazing. But how do you do the side without mucking up the top?
You have to do a spatter finish!
Rafa
Looks nice  ;)
I wonder how they do it in th factory, my brother has a slammer with 3 color sunburst
Rafa
  This is a good method, your box turned out great !!!
  I cheated and used a 1'' round lid to raise the mask off the box, set the mask on that, then a weight to keep the light cardboard mask in place on the box in the wind...
