Transformer question about the ultra clean power supply!
Started by Akuma60, November 12, 2006, 10:31:58 PM
Akuma60
I'm planing to do the Ultra Clean Power Supply!
I've looked at mostly all the topics about that projects and it got something pretty clear, we can use 12V adapter
I need to clarify some little details!
1 - Will my adaptor be ok if it has this mention  "12VAC 1A Center Tap Transformer 6-0-6"  ?
2 - Since it is center tapped, do I ground the CT  ?
3 - If I use this adaptor, do I need to change something in the layout of the other components (or components itselves) of the project  ?
Akuma60
Okay, I've got the answer by myself for # 1 and 2.
What about question # 3  ?
Akuma60
Then again, answered it myself by doing the project!
So if you have a center tapped transformer, don't solder the CT to anything and you don't need to change the other components if you use a 12 volts transformer!
Thanks anyway!
PS  great project (Ultra Clean Power Supply) easy to build and very compact!!
fikri
