Wah pot for trem speed?
Started by rhys, November 14, 2006, 08:45:54 AM
rhys
if i want to put a tremolo pedal in a wah casing and have the rocker control trem speed, will one of the wah pots smallbear carries work?  steve carries a 100k wah pot, but apparently wah pots have a unique sweep; my reservation is that it would give good control over the middle speeds but no control over the slower and faster speeds.
  Between the rack/pinion gear adjustments and using tapering resistors/stop resistors...I guess...you'd be able to get the tremolo speed controlled to your liking using a wah Case/Wah pot.
  If all else fails a 'two stage fine tune' switch could be used to select between two smaller speed ranges/finer speed adjustments.
Sweetalk
Try changing the pot... There are Bourns (made of Cermet)  pots that fits perfectlly in the wah, they are linear tapper.
The Tone God
#3
Depending on what parts or tools you have available you could replace the pot. The pots used in most wah circuits have 6.25mm (1/4") D-shape shafts. If you can only get round shaft you can file or grind down part of the shaft flat so it can take the gear.
Just a some thoughts.
Andrew
lacto
You could get a Roger Mayer wah pot, as they are linear taper too.
