Rotary switch lugs have no holes
Started by mtlin, November 15, 2006, 04:47:10 PM
mtlin
I bought a couple of rotary switches from Small Bear. One of them has lugs with holes, like I'm used to. The other has no holes. Its lugs are just like thin posts. Any ideas on how to get a good mechanical connection before I solder?
Martin
puretube
MikeH
mtlin
puretube
sfr
Are you certain that the other one isn't a board mount one?  I thought I had a PCB layout for doing those up, (these are the Lorlin rotary switches, right?)  but I can't seem to find it on my harddrive.  (suppose you could just copy out the bits from R.G.s Great Cheddar layout)
bancika
in such cases I just twist pins into circular shape and get a lug  :icon_wink:
MartyMart
Strip about 12mm of wire at one end, tin it with solder, use small needlenose pliers to shape it
into a " C " shape and loop it round the post - solder - done !
MM
