Need help for NJM4558S pinout
Started by wui223, November 17, 2006, 06:59:01 AM
wui223
I have a NJM4558S in box, but i couldn't find a single datasheet for it. It has 9 pins. Is there any way to know the pinout of this IC w/o datasheet? Help is very much appreciated.
Sir H C
wui223
Yes,i swear it 8). I know its kinda weird, but it IS a 9 pins buddy. Anyone?
Sir H C
I would look at the 8 pin one and get a feel for what the pins should be on the 9 pin version.  From the PCB you should be able to figure it out.
wui223
Unfortunately, it is a brand new chip i bought from shop.
Dai H.
pin 1 should be +V, 2 to 9 should be the same as the 4558L
wui223
From the datasheet of NJM4558L, pin 8 is V+. If pin 1 of 4558S is V+, how about pin 9 of 4558S ?
mdh
Take a look at this Fairchild data sheet: http://www.fairchildsemi.com/ds/KA/KA4558.pdf. I'll bet your pinout will be the same as the 9-SIP package from Fairchild.
wui223
Thanks alot to everyone. This mystery finally solved after 1 year. Now is time to make something out of it. Any suggestion? Tubescreamer?
