A suggestion for a 9V power supply
Started by Gilles C, November 17, 2006, 12:35:53 PM
Gilles C
While I was waiting for some power jacks to complete the Spyder power supply I built a while ago, I realised I also needed a separate 9V power supply to take with me when I was using only one guitar effect and didn't have any battery for it. Or just because the battery of a pedal suddendly decided to quit on me and that I didn't have any battery left.
So I used the same layout than for the Spyder and built one, but used only one regulator circuit.
Like this:
I used a bigger capacitor before the regulator, but was able to use the same traces. I also added a LED to the circuit.
I just bought a cheap 9V DC/150ma walwart, cut the wire, and added the regulator board to it. Btw, if the polarity of the plug is not originally correct, you just swap the 2 wires on the plug side to have the (+) and (-) at the right place. Easy, cheap and fast. All it needs right now is a plastic box to house it.
I found some cheap walwarts that were cheaper than what I paid for only a cable assembly with a power jack already installed for the Spyder. The walwarts were $1.50 CAN, so I bought the 7 they had, just in case I needed more later... The wire guage is a little smaller, but you can't beat the price.
I built that 9V power supply a while ago, but I had a few questions lately from a couple of guys about the spyder circuit, so I thought it would be the right time to post this.
Here is about the Spyder details:
http://www.diystompboxes.com/smfforum/index.php?topic=48673.msg361194#msg361194
http://www.diystompboxes.com/smfforum/index.php?topic=48084.msg363764#msg363764
Gilles
