Texas Cattledrive in the gallery
Started by markm, November 24, 2006, 01:10:33 PM
markm
Quote from: Gilles C on November 27, 2006, 09:10:04 PM
Did you have to adjust the values of the resistors a lot?
I read some comments today that a few builders had to use larger resistors at the base and at the collector.
Gilles
No, with the single exception of the trimpot, I built mine exactly as the schem reads and it sounds real good.
Gilles C
#21
Cool! It means the transistors are doing the job.
I forgot to add that those having problems with adjusting the resistors were not using Aron's transistors. They were using ACxxx and OC44 from another supplier.
Thanks. I am also using Aron's transistors...
I'll start the build as soon as I can find the time.
Gilles
