Easy Vibe Led Orientation
Started by axeman010, November 26, 2006, 11:44:26 AM
axeman010
Hi all
having problems with an Easy Vibe - cant get the LEDs in the Opto Couplers to light ( the Biasing ones do light up !)
Please can any body confirm the Orientation of the fours leds from R.G.'s  Layout - So looking at the component side of the board should the anode (+)
be on the left or the right ?
Also what voltage should I be reading across the LEDS please ?
Many thanks
Axeman.
Hanging on in quiet desperation is the english way
jimbob
I had the same question as Im working on one right now. I also noticed that the pdf doesnt show oriention + or- for the electros. Does anyone have a schematic as well as the info above?
"I think somebody should come up with a way to breed a very large shrimp. That way, you could ride him, then after you camped at night, you could eat him. How about it, science?"
axeman010
Jimbob
I can help with the elec. caps.... on the PCB the +ve side of the cap has a square hole on the PCB, rather than round.
Hope that helps !!!!!!
Axeman
jimbob
tcobretti
axeman010
OK - thanks Tcobretti
I had Effect wont work blindness, caught by staring at a PCB that does not work and switching of your brain!!!!!!!
The anode (+) should be on the right hand side for all 4 leds when looking at the component side of the PCB.......... I think????
Aaaarrggghhh no !!!! I have now got indecision, caused by..... used guessed it !!!!! ........ staring at a PCB that does not work and switching of your brain !!!!!!!
Axeman.
