baking enclosures...safety tips?
Started by jonathan perez, November 27, 2006, 06:01:08 PM
jonathan perez
what precautions should i be taking? also, whats the typical timing process for a paint-design-gloss finish?
goodrevdoc
I usually go 30 min @ 200F per coat. Ventilation and burning yourself are probably the two big saftey concerns. Although I wouldn't do it in an oven you bake pies with.
-justin
darron
Lachlan C.
As mentioned by others, you shouldn't be baking painted pedals in the same oven you cook with. Even if you aired the oven after use the chemicals in the paint vapour adhere to the walls of the oven. Not so good for your health!  :o It's probably best if you can pick up a small toaster oven (usually for fairly cheap) to use specifically for baking your creations.
Hope it works out - Lach
