Neutron filter--odd value for "down" bias....
Started by celamm, November 29, 2006, 10:57:31 AM
celamm
Not sure if this is right or not....
To make the "down" bias setting sound OK I have changed out the 120K resistor with 10K.  I am talking about the 180K/120K voltage divider that feeds the inverter.
This seems a bit drastic to me, but seems to work.  Did anyone else have to make this radical a value change?  I have gone over the circuit and can't find anything else wrong.  Note that I am not using batteries, so I can't see how this value change is going to "hurt" anything.
I am using 47uF instead of 4.7uF for the decay cap and 4.7K for Rx.  Other than that stock values are used everywhere.  I am OK with the sweep but not the decay time, so I may mess with this some more.  but I can't see how these values will affect the down bias in any event.
I am using the special 1 LED + 2 resistor can from small bear for the opto.
celamm
Update.  I spent some more time on this pedal yesterday.
--I am finding an interaction between the "down" bias and the value for Rx.  Since the Rx value affects half the inverting side of op amp U3a I guess this makes sense.
--I have put in a 22uF cap for c9, a 10K multiturn trimmer for Rx (dangerous--don't want to make the - of the opto see ground or maybe it'll blow up) and a 100k trimmer for R19.  So far this has yielded the most musical results.  I am surprised how small the "sweet spot" is for the best match between up and down bias.  However, I am still not 100% happy with the sweep, esp for the down direction.
I am next going to work on knocking down some of the gain--the gain stage gives me a lot more gain then I need right now.  After that hopefully I'll be done....
BTW in case anyone out there is still listening....I have another question--why is C1 spec'd as tantulum?  Isn't using tant caps in the signal chain a no-no because they sound crappy?  Can a electro be used here instead w/o affecting the quality of the sound?
