Tube reamer mod question: MORE compression WITHOUT more distortion?
Started by Xavier, December 05, 2006, 07:26:58 AM
Xavier
Can this be achieved?. In my eternal look for the overdrive that suits my needs, I've decided to breadboard a tube reamer as it's a fairly simple circuit, just to try some tweaks, one of them being actually more compression. I'm not looking for more gain as I have other pedals for that. I guess I'll have to tweak around the clipping section,
Is it unavoidable more compression=more gain?
WGTP
Might try using Mosfet clippers instead of standard diodes.  They compress more before clipping.   :icon_cool:
Stomping Out Sparks & Flames
Xavier
Quote from: WGTP on December 05, 2006, 10:54:11 AM
Can I use BS170's for that? I don't have any IRF510-520.......
WGTP
Yes, but the clipping threshold will be fairly high, over 2 volts.  Could be just right.  Supertex has some that might work better for you.
Check this out for details:  http://www.elixant.com/~stompbox/smfforum/index.php?topic=38581.0 :icon_cool:
Also this at AMZ.  Try the SECOND one:  http://www.muzique.com/lab/zenmos.htm
Elektrojänis
How about using leds as clipping diodes and then wire a LDR parallel to those clipping diodes. Then set the leds and the LDR face to face and put them in to a light proof container.
I have tried this with some other opamp feedback clipping circuit and if I remember correctly it worked at least some way. In my circuit the opamp was in inverting configuration though. It was years ago and I never really refined the circuit (and I have disassembled it as it was just an experiment).
Different leds an especially different LDR's will give different results ofcource.
