replacement trannies for coloursound supasustain > BC169B to BC549
Started by ulysses, December 06, 2006, 09:57:35 PM
ulysses
hey guys
anyone built the coloursound supasustain?
what trannies did you use? i should be able to swap out the BC169B's for BC549's right?
cheers
ulysses
jonathan perez
ulysses
the datasheet ive got says the 169b has a hfe min max @ic is 180/400@5ma
the datashee ive got on the bc59 has a hfe min max @ ic is 110/800@2ma
how do i compare the two variables given the ma rating is listed differently?
cheers
ulysses
rocket
the b suffix of the bc169 says it's medium hfe. the bc549 also comes in b anc (higher hfe) so just use the bc549b also the bc548b or bc547b should work.
probably any npn transistor with a gain of more than 100 will work
mac
Sometimes replacement transistors sound almost like the original ones in some circuits. In the case of Fuzz Face-like circuits replacement transistors could sound different. Never tried a Supasustain but I geuss that a 2n2219, bc140 or 2n5088 could have their own flavour.
mac
Ge_Whiz
