Boss DM-2 low output and repeat pot is bunched up.
Started by golden_virgin, December 07, 2006, 11:20:42 AM
golden_virgin
I recently acquired a DM-2.
The output seems to be quite low compared to when the guitar is plugged in direct to the amp. Does anybody know what factors might be causing this?
Also, the Repeat Rate pot has been replaced sometime in its life by the sounds of it. Theres a big jump in delay time at the end of the pot. Does anyone know what pot I need to replace this with?
Also, theres a wire come lose from point 13 and I'm not sure where it goes.
Any help on this would be much appreciated.
thanks
calculating_infinity
Hey man.  The Repeat Rate knob should be a 1meg pot.  It could be that a previous owner adjusted the trimpots inside that causes the huge jump.  Check the pot on the pedal you have now.  It should definately be 1meg.  There should be a schem on google images for your other prob.  I dont really like to open my DM-2 (only did it once to check which bbd i had).  Anyways I hope that helps any.
