Am I in need for Mullard transistors ?
Started by warioblast, December 11, 2006, 03:19:37 PM
warioblast
Hi,
I put a tone bender MK2 on my breadboard. I used 2 ASY25/3 & an AC122. No matter how I bias the transistors I still can't get that legendary decay. Are Mullard the only way to go ?
Cheers,
Fabrice
  no..read GEO technology of the Fuzz Face.
  and Q1 in the TB...IIRC it needs to be a little leaky to bias right?
  Testing GE Transistors of different Hfe for the FF section [Q's 2 and 3] See above read for more info, and Q1?...try some different ones there.
  Check ROG, they have target voltage measurements for the TB MkII Pro, perhaps having a handful of Ge Transistors and doing some bias...
  First thing I'd do is check Q3 collector voltage, but measure all the transistor voltages and post like
  Q1
E .2
B .7
C 3.8
  Q2
E  .0v
B  .43
C  1.2v
  and so on
  Q3
  No...Smallbear electronics sells TB MkII Pro Ge Transistor sets, tested for leakage/Hfe/calculated bias values.
Dragonfly
Quote from: petemoore on December 11, 2006, 03:38:46 PM
  First thing I'd do is check Q3 collector voltage.
yep...as dumb as it is, Q1 is "leakage biased !"  Yet another reason why you cant just drop a silicon PNP in there and expect it to work.
AC
  Not without adding a resistor to create a V+/- bias string on the base a'la Ricky Vance Si TB.
