AX84 High octane's preamp section STOMPBOX
Started by frickecello, December 20, 2006, 06:55:03 PM
frickecello
Hi, I was looking at AX84 projects and found the HO very interesting, has anyone already built the preamp section into a pedal?
it has exactly the same topology as the hoffman tube preamp and the matchless hotbox...
YouAre
its been done i believe. if i'm not mistake, it didnt have good results :-\
issues with noise because it was so high gain. wiring would be much tougher in a stomp box.
Doug_H
It's basically a jazzed up Marshall 2203/2204 preamp, the basis for many high gain amp circuits and etc. No reason you couldn't put that in a pedal if you wanted to.
frickecello
Thanks for your reply, yes its exactly the same topology as the marshall 2203 preamp, any advice for making it as quiet as possible?
frickecello
Yes it worked very well, I will build a 2203 preamp, Im very satisfied with the tone..
