Preform channel-switching and effect in/out with one switch?
Started by JJRockford, December 25, 2006, 06:49:42 PM
JJRockford
Is it possible to build a usual channel-switching box (for a 2-channel amp) which could switch effects in and out at the same time? That should be a combination of a channel switch and a bypass-box if you know how I mean?
Please visit VII Gates official homepage at http://www.sevengates.se
Seljer
yep, its possible
for channel switching, most amps just have you connect the tip of the 1/4" plug to the sleeve with a momentary switch
on a 3DPT switch that leaves another 2 sections that you can use for a bypass loop (or 2 completely different selectable loops)
Meanderthal
Pushtone
There already is a looper on the market with this very feature.
The Tonebone Loopbone.
http://www.tonebone.com/tb-loopbone-using.htm
I've been wanting to do this too on a homebuilt looper but
to make it compatible with as many amps as possible it would
need the tip/ring and momentary/latching switches found in the Loopbone.
The Loopbone seems to cover all the bases with these switches.
The tip/ring switch is important on amps that have channel switching and reverb on/off with one TRS 1/4" jack.
The latching/momentary thing is also mandatory if one is to use a looper with many different amps.
My Vox AD30VT like a latching footswitch for channel switching while the Line6 Spider prefers a momentary.
JJRockford
Radial effects are pretty expensive. But it's still maybe worth the money, comparing to build one yourself? Or are there any similar schematics? Could do it without the midi-feature...
Ben N
I know this is more than you asked for, but worth the read just to get ideas--some kind of CMOS/relay system would work great for that, and RG Keen has a lot of stuff on his site that you can use as is, or simplify/modify for your needs.  Check it out.
http://www.geofex.com/Article_Folders/remoteftsw.pdf
http://www.geofex.com/FX_images/relays2.gif
http://www.geofex.com/Article_Folders/cd4053/cd4053.htm
http://www.geofex.com/Article_Folders/fxswitchr/fxswitchr.htm
Ben
d95err
Quote from: Seljer on December 25, 2006, 09:01:56 PM
On most amps I've seen it's a latching switch (unless the amp has lots of digital junk in it). This is easy to test, just plug in a regular 1/4" cable and see what happens when you short the tip-sleeve of the other end.
If the amp wants a latching switch, you can simply use a 3PDT switch and use one pole for the amp switching. If you want LED indication, you could use a millenium bypass, or use a non-true buffered bypass.
Pushtone
Quote from: d95err on December 27, 2006, 02:55:41 AM
Perfect!
I would go with the input buffer to split the signal to the loop send jack and bypass with a 3PDT to yield an LED indicator.
You could put a second switch 1/4" jack in to give you a choice of buffered input and non-buffered input.
I drew it up. I added a polarity switch to select tip OR ring to be used with amps that have one TRS footswitch jack that does channel and reverb switching.
d95err
Different amps may have implemented the switching differently. I.e. in some amps, shorting tip and sleeve will mean "OFF" and on other amps "ON". Therefore, you may want a switch to change if the loop is connected when Tip-Sleeve is closed or when it's open.
You can implement this with an SPDT: (Hope this makes sense)
FS = Footswitch
PH = "phase" switch
      FS    PH
Tip---*      *-----GND
Pushtone
Yes,
I understand how that would be important for compatibility among amps.
I tried to add this feature to the drawing. This should work OK.
I called it a STATE toggle, as in what "state" the amp channel is in.
Also drew in the second un-buffered input using a switching jack for times when an booster
pedal is used in front, or when the looper is fed from a buffered output.
So the only thing not covered is the momentary vs latching thing.
I think amps that respond to momentary channel switch signals are rare.
I can't think of any. But it might be cool to start / stop a drum machine via footswitch.
