Cannibalized Germanium Transistor Fuzz/Dist. Circuit Ideas ?
Started by Rectangular, January 03, 2007, 09:52:37 PM
Rectangular
Hey guys,  I recently cannibalized a slew of parts from an ancient sony Reel-to-reel. I ended up with a lot of old transistors as well,  but one in particular caught my eye, its a Germanium PNP in a CAN package. I wanted to know if someone could recommend a simple fuzz/overdrive/distortion type circuit that I could test this thing out in. I also got some silicon NPN's and old germanium diodes (voltage drop was around 412 for the diodes)
thanks for your time
-Rec
zachomega
What model transistor?  Did you measure the leakage and gain?
-Zach Omega
Rectangular
no measurements on the transistor yet,  I can't seem to find a datasheet on it. its a Sony B383.. actually, Ill just test it right now.. I don't know the pinout,  so I just randomly oriented it in the multimeter until I got a number that looked 'right'...  118  hFE
zachomega
If the leakage is low, that might make for a cool treble booster.  I just built one last night and love it.
-Zach Omega
Rectangular
I'm just assuming the best thing to do with this, is to use it in some kind of  fuzz/distortion circuit.  This is because the only time I read about germanium transistors/diodes anymore, is in fuzz-type circuits. perhaps these germ. transistors have a better application ? or maybe its completely generic and useless... I've no idea
zachomega
Most fuzz units require multiple transistors.  Treble boosters or clean boosts or whatever use 1 transistor a lot.
-Zach Omega
Rectangular
yeah, you're right... I was eyeing a PNP fuzzface, but I'd require another one of these. can you recommend a PNP booster ?
Rectangular
The creampie looks like a simple build, is there a PNP version perhaps ? I searched, but only came up with a PNP (as in Press-n-Peel), so wrong acronym
