Reverse Power Booster
Started by WGTP, January 05, 2007, 01:20:25 PM
WGTP
http://www.muzique.com/lab/reverse.htm
This is an attempt to get Jack to elaborate on how the harmonics of the clipping produced by this circuit differ from typical clipping.
Also, the AMZ CD has a lot of cool stuff on it, if you haven't checked it out yet.   :icon_cool:
Stomping Out Sparks & Flames
Dragonfly
ive wondered how the RPB would work as a recovery stage AFTER a tone control like the big muffs ? the different harmonic content might be interesting, and IIRC, the 12dB or so gain should be plenty...
just a thought.
AC
  That's brisk Baby !!!
  I was checking that thing out !!
  That's not yer typical booster...
  Before, after, or during...these are the options.
Ronsonic
Time to clear a breadboard.
Ron
http://ronbalesfx.blogspot.com
My Blog of FX, Gear and Amp Services and DIY Info
amz-fx
Quote from: WGTP on January 05, 2007, 01:20:25 PM
This circuit is using a transistor oriented against its typical operating conditions...  when it is driven hard, the signal has a tendency to "fold-over" as the current flow tries to reverse into the normal direction.  This fold-over adds some interesting harmonics.  The clipping is totally unlike that from diodes or even boosters driven into clipping.
The specific transistor characteristics will have a lot of influence on how it performs in the circuit...   modern heavily doped transistors actually are not as interesting as older devices.
regards, Jack
$uperpuma
what types of devices have you tried like this , Mr Orman? I'd like to experiment a little... and don't have 0c44's or ac128's on hand :)
