Negtive voltage on gate - English Channel ROG
Started by Pushtone, January 06, 2007, 12:51:58 PM
Pushtone
I'm biasing an English Channel build.
The effect sounds the way I think it should, no gating, good sustain etc.
But the gate for trasistor Q5 is less than zero at -0.14 .
The ROG page tells me it should be zero.
Should I be concerned with a negitive reading on the gate of Q5?
Here are my pin voltages with an 8.8V supply
Q1:
D: 4.40
S: 0.18
G: 0
Q2:
D: 4.40
S: 0.21
G: 0
Q3:
D: 8.88
S: 4.41
G: 4.40
Q4:
D: 4.57
S: 1.41
G: 0.878
Q5:
D: 4.46
S: 0.02
G: -0.14 (negative??)
Here are the pin voltages from the ROG page with an 9.1V supply
Q1:
D: 4.57
S: 0.174
G: 0
Q2:
D: 4.55
S: 0.164
G: 0
Q3:
D: 9.11
S: 4.79
G: 4.55
Q4:
D: 4.59
S: 1.41
G: 0.878
Q5:
D: 4.61
S: 27mV
G: 0
Ge_Whiz
If it sounds okay, no. But you should be measuring relative to the ground, or battery -ve, in which case, you can't measure something negative relative to this. I suspect a problem with the connections for that measurement. When the battery voltage is okay though, everything is all right, so don't sweat.
Ardric
Maybe a bad 47n coupling cap from Q4, or a bad 4n7 cap on the cut control?  I imagine a reversed polarized electrolytic in either of those spots could cause the gate to go negative.
