Source for long-leg PCB mount Alpha 16mm pots?
Started by skiraly017, January 19, 2007, 02:25:01 PM
skiraly017
Since the search function is down I couldn't use it to find this out. I'm looking for Alpha 16mm PCB mount pots with the long legs. I checked Mouser but could not find any. Does anyone have a source? Thanks.
Pushtone
I could not find such a beast either.
I ended up soldering cut-offs from resistors onto the standard pot lugs.
At least you can control the length this way.
I wanted to PCB to sit in the lid (bottom) of a 1590B so the leads where long(ish).
Good luck
skiraly017
#2
I found out the correct term is "right angle PCB mount'. I know Alpha makes them, they're in my VL Sparkle Drive. Unfortunately the Alpha catalog is not the most user friendly.  :icon_frown:
rockgardenlove
skiraly017
Quote from: rockgardenlove on January 20, 2007, 12:47:55 AM
Like the ones in EHX pedals?
I don't have an EHX pedal for reference, but if I had to guess I'd say yes.
The Tone God
PCB mounted pots, particularly with odd leg styling, are not that popular amongst hobbyists so I think you will have a hard time finding a small volume supplier. Those types of parts usually have to be ordered in large amounts.
Andrew
smallbearelec
Scott--
I have gotten some of these made for other boutiquers. Minimum order for a value/taper is 1,000 pieces, delivery about 8 weeks, price $ .65 - $ .75 each F. O. B. Brooklyn depending on the exact configuration. Alpha will make samples for me before committing to production. If you want to go this route, drop a message at smallbearelec@ix.netcom.com.
skiraly017
Quote from: smallbearelec on January 24, 2007, 07:17:22 AM
:icon_eek:
Seriously, that's good to know. I'm not quite ready for 1000 pieces but at least I know I can get them.
