Univox superfuzz VERO layout?
Started by rove, January 20, 2007, 03:13:52 PM
rove
Can't edit my previous post, but I think it is apparent that my fuzz knob is wired in backwards still  :icon_redface:
thanks for the pix and ideas!!!
rove
I just rewired the fuzz pot to go in the right direction and went ahead and added a 5k starve pot, which really does sound great and add more to the versatility of the effect.  Would you mind explaining the way you rewired the switch into a knob? what value pot, for example.  I think that a knob to go from one extreme to the other would be far more useful (and thus used) than the current switch, though I had considered using a stompswith to go from one to the other...
meanwhile I'll see if I can't dig up the mod you did somewhere on the forum.
Again, I am super happy with this pedal thanks for sharing the layout.
rove
Ok, a little research yielded the following info:
placing a 50k pot between the .1 cap to ground and ground wired as a variable resistor will give the blend between the notch mode and full mode.
Thanks Slacker and Mark Hammer.
I have implemented this and it works except I need to use a linear pot as the log  I used for test purposes bunches a lot of the change at one end, as one would expect.
hellwood
does anyone know why unicords schematics dont show polarized caps?
pinkjimiphoton
hi guys, sorry to shock a zombie back to life, but any chance some kind soul may be able to re-up the vero layout for this beast?
thanks!!
Slava Ukraini!
~Jack Darr
It's in my gallery, if you follow the layout gallery link and then search for slacker you should find it. I would post a link but I can't figure out how to do that using tapatalk.
tubelectron
I think I may help you - here's what I have done some times ago for my daughter which wanted a SuperFuzz, and it works +++ :
Sorry - some comments are in French !
A+!
I apologize for my approximative english writing and understanding !
http://guilhemamplification.jimdofree.com/
rousejeremy
You solder the components on top of the copper tracing side? I've never seen anyone do that before. Any particular reason?
Consistency is a worthy adversary
www.jeremyrouse.weebly.com
pinkjimiphoton
Quote from: tubelectron on February 17, 2012, 03:31:18 PM
A+!
merci beau coup mon ami!!
thank you so much!
Slava Ukraini!
~Jack Darr
tubelectron
Quote from: rousejeremy on February 17, 2012, 04:13:40 PM
Well, I felt it was more easy to avoid placement errors, as the circuit is let flat on the table and in direct correspondence with the layout drawing... Nonetheless I use the classic method also, which is more easy to solder.
A+!
tubelectron
Quote from: slacker on February 18, 2012, 06:22:30 AM
Mine's here, in case people want it again in the future
http://www.aronnelson.com/gallery/main.php/v/slackers-stuff/superfuzzboard_final.jpg.html
slacker,
1 - your layout is more compact than the one I used +++
2 - which software you used to design this layout ? It seems even better than DIY Layout Creator...
Thanks & A+!
pinkjimiphoton
again,. thanks slacker! looks good!!
Slava Ukraini!
~Jack Darr
Quote from: tubelectron on February 18, 2012, 08:33:21 AM
I just use a graphics program, I have a large image of the veroboard and the components are in a gif image with a transparent background. To make the layouts you just copy and paste the components on to the veroboard image.
Here's the images if you want to give it a try.
http://www.eskimo.plus.com/fxstuff/board.jpg - veroboard
http://www.eskimo.plus.com/fxstuff/components.gif - components
cab42
I use the same method as Slacker, however I use the templates from Dragonfly in the gallery:
http://www.aronnelson.com/gallery/main.php/v/DRAGONFLY-LAYOUTS_0/The-Mod-Zone-_/?g2_page=3
Regards
Carsten
"Rick, your work is almost disgusting, it's so beautiful.  Meaning: it's so darned pretty that when I look at my own stuff, it makes me want to puke my guts out."
Ripthorn
tubelectron
Thanks slacker and cab42,
In fact, what you use is purely "manual drawing" method - I though you were using a dedicated software...
Nonetheless good idea, applicable on word, publisher, powerpoint or so, I presume.
A+!
cab42
Quote from: tubelectron on February 19, 2012, 05:47:31 PM
A+!
I use Paint for the task. Lightweight, easy to use and available on any Windows PC (even at work :icon_wink:) .
Last week I made my first schematic from scratch using the same approach with symbol templates I found here and on GGG.
Ripthorn
tubelectron
QuoteI use Paint for the task
Ah, OK - even simpler, then ! Thanks for the tip...
A+!
