Alembic F2B Tube not light up
Started by wui223, January 30, 2007, 05:27:04 AM
wui223
I build the Alembic preamp, but after i connect everything, the tube is not light up. I tried both 12VDC and AC supply, still nothing happen. I check the voltage of B+ and heater, it is fine. Anyone could point out what would have happened?
bancika
how did you wire tube heaters?
measure voltage between pins 4 and 5
wui223
12V to pin 4 and 5. Pin 9 to ground. Voltage across pin 4 and 5 is 12V
bancika
wui223
Fixed. I messed up the pin out, all reverse in order. Now the tube is light up, but no sound at all, previously there are whinning/humming sound now totally silent.
JonFrum
Measure your voltages at each tube socket lug and compare them to what you expect. If you don't know what to expect, list them here.
The Tone God
Pin 9 should not go to ground if you are using 12v. Leave pin 9 unconnected.
Andrew
JonFrum
Quote from: The Tone God on January 30, 2007, 01:49:19 PM
Andrew
Are you sure about that?
The Tone God
Quote from: JonFrum on January 30, 2007, 02:45:06 PM
Pin 9 is the centre tap of the heaters. The ends are pins 4 and 5 with the complete heater running at 12v so you need only pins 4 and 5 when running at 12v. Pin 9 is used if using 6v otherwise leave it open.
Andrew
rockgardenlove
moosapotamus
Huh, maybe that has something to do with why I prefer the sound of mine running 6.3V to the heaters instead of 12V.
~ Charlie
moosapotamus.net
The Tone God
Quote from: moosapotamus on January 30, 2007, 03:41:05 PM
Umm...I am kinda slow these days but you are kidding right ?
I think the OP is shorting one triode heater by grounding pin 9 which would explain the no sound but some heater action happening.
Andrew
JonFrum
Quote from: The Tone God on January 30, 2007, 02:57:57 PM
Andrew
The reason I ask is that Fred's Real McTube schematic shows pin 9 grounded.
The Tone God
#13
Quote from: JonFrum on January 30, 2007, 04:09:37 PM
I have not seen the schematic so I cannot comment besides that would also be a borderline threadjack for the OP. ;)
Andrew
wui223
Hi Charlie, i saw that you built Alembic preamp also. Could you post the voltage for each pin just for reference?
bancika
in will work without grounding pin 9 but I think that it should be connected to a reference point, ground or some positive DC voltage (in amps it can be output tube cathode). I read that it can help reduce noise.
The Tone God
Thanks PT! :icon_biggrin:
In that schematic they are half wave rectifying a 12v centre tap transformer so really pins 4 and 5 are getting 6v so you would need pin 9 ground to complete the connection.
Andrew
moosapotamus
Quote from: wui223 on January 30, 2007, 05:45:11 PM
Sure. But, I might not be able to get to it until after the weekend. If you post your voltages, I'm sure folks could tell you if anything looks questionable.
BTW, my B+ is ~300V and I actually do like the sound better with the heaters at 6.3V than with them at 12V. ;)
~ Charlie
moosapotamus.net
The Tone God
Quote from: moosapotamus on January 30, 2007, 09:07:12 PM
Okay so that is 6.3v per heater half verses 6v making for a difference of 0.3v. I don't know what kind of difference 0.3v in the heater would make to the conduction of the cathode but I wouldn't count on much. For me I see it as one of those "mojo" things. If you like it that way then by all means go for it. :)
Just my opinion.
Andrew
