Most Rat like distortion?
Started by jpm83, January 31, 2007, 01:53:42 PM
Dragonfly
JPM...
you can find a verified vero layout for the jerkulator in my gallery...
AC
boyersdad
I just built myself a turbo/RAT (switch between the two sets of clippers) using the LM308N (8pin dip, not the metal can). It was $4USD from www.smallbearelec.com, which I'm sure many here are familiar with.  The metal can version is a whopping 50 cents more. I know it's almost 10 times more than most popular opamps, but hey, it's still only $4...
I like amps etc.
jpm83
Thanks for info´s. And thanks for all of the layouts Dragonfly, your booster is just great.
   Boyersdad I live in Finland and I don´t have a credit card so I can´t order from smallbear, but thanks for a   hint anyway.
Janne
jpm83
#23
Is this layout right. I used Dragonfly layout as an base and added the diode clipping section. http://img523.imageshack.us/my.php?image=moddedjerkulatorlu3.gif
Janne
jpm83
I tried to make layout for this mod to Dragonflys layout. http://www.home-wrecker.com/harmonic.html
   Did I make it rihgt or is there errors.
Janne
tcobretti
Looks correct to me.  I may have to build this one,too.  It sounds pretty good!
Ed G.
I would say the most rat-like distortion is the Rat.
To paraphrase Nigel Tufnel (how appropriate!)
"How much more Rat can you get? The answer is none. None more Rat."
aron
QuoteI would say the most rat-like distortion is the Rat.
uh.,... yeah, there's a distortion called the RAT.
http://www.ratdistortion.com/
Maybe they mean RATT!
http://therattgang.com/
WGTP
I still think they are sort of jerking folks around by having 3 different pedals instead of a 3 way switch.  IIRC someone mentioned the op amp in the newer models, but I don't remember where.   :icon_cool:
Stomping Out Sparks & Flames
tcobretti
WGTP
