FX projects utilising CD4049UBE - have I missed any?
Started by wondergibbon, February 03, 2007, 10:01:08 AM
wondergibbon
Greetings all, from the token female from what I can establish.  ::)
I have a cache of 50 CD4049UBE, and I am looking to utilising some. My research here and on other sites indicates that the following effect circuits use this IC
Anderton TSF
49er
22 7ths
Hot Harmonics
Red Llama
UbeScreamer
3 Legged Dog
Double D
Mr EQ
Ultraflanger
Zombie Chorus
Insanity Box (a good description...   :icon_rolleyes: )
Other circuits have tried but have not been good.
Have I missed any working ones?  ???  I did take notes but I am sure that I missed up some. Are there any others that this chip could drop into ?
I did search here and the layouts folders. Some were about switching with the IC. So I did try.
Many thank yous. Let the games and fun begin.
-the wondergibbon.
(It is best not to ask- it is a long and not interesting story.)
Seljer
I'm not sure about how different they are but the MXR Envelope Filter uses CD4069 inverters
KerryF
Thanks!  I have a crapload of these too and have been looking for cool things to use these for.  Breadboard, here I come  :icon_twisted:
wondergibbon
There is also the MXR Hot Tubes, schem at Experimentalists Anaonymous, although the note reads it have a lot to do with the TSF. I don't know if that counts.
-the wondergibbon.
markm
Meanderthal
Meanderthal
#6
 Oh! and Tim Escobedo's Cmos Drive, and Cmos Boost(built that one, it's great, and like 5 parts).
Edit- oh jeez, and his Ghost Dance and Calavera. They don't mention the 4049, but the cmos boost works fine with it, and I'm sure the others will also, just check the pinouts.
The Tone God
Quote from: markm on February 03, 2007, 11:46:33 AM
I found this on the net quite awhile ago;
http://i17.photobucket.com/albums/b72/mmarkmm/ETILimiterPage3.jpg
I built that in 1982 or so, and it works as described, but it's a little on the noisy side.  Might work a little better with certain components (semiconductors) chosen for noise specs, since the 4049 serves only as a voltage-controlled resistor.
While we're at it, the ETI 6-stage phaser from the same era uses a 4049 as votlage-controlled resistive elements instead of FETs.
Zero the hero
Bad Stone uses a 4009 which is a 4049 direct replacement.
wondergibbon
Thank you everybody! I will be busy for a while, for sure. ;D
-the wondergibbon.
