if my battery heats up....
Started by southtown, February 03, 2007, 07:22:35 PM
southtown
and my contnuity tester beeps when i put the leads on the empty battery clip, it means what ?
zyxwyvu
That means you have a short somewhere between power and ground. You should check for extra solder joints or other places they could connect.
 Reverse the order, postpone the second task...
  Test for non-continuity between V+/V-, don't connect PS...eliminate shorts before supplying power.
southtown
i got it, took me about 2 hours to find a little piece of solder has bridged 2 strips
