OT:Search engine question
Started by modmod, February 05, 2007, 11:26:07 PM
modmod
i'm recently searching info about boss pedals,and the results are always 06-07,i know there are tons of older posts,anyone know how to search older posts ? thanks :)
Alex C
When you click the "SEARCH" button, under the search dialog box there is a link titled "Advanced Search."  The "search order" drop-down box allows you to list results by date in order of most recent or oldest.  You can also search a range of "days ago."
P.S.  It's no problem, but threads like this are better suited for the Lounge.
The Tone God
What search criteria did you use ?
Andrew
modmod
Quote from: Alex C on February 06, 2007, 01:02:49 AM
i did,you can try "cs" ,"cs-3"........... :icon_confused:
The Tone God
Two or three characters, even being a specific company's model number, is usually not a good or specific enough search criteria. Also not everyone uses the model when posting information so that is a somewhat weak search criteria.
Instead I used this search criteria: boss compression sustainer
and came up with this:
http://www.diystompboxes.com/smfforum/index.php?topic=48287.0
http://www.diystompboxes.com/smfforum/index.php?topic=24695.0
Andrew
modmod
Quote from: The Tone God on February 06, 2007, 03:10:05 PM
Andrew
thanks for that,but you see there is "cs-3" in the topic,and how come when i search "cs-3" and i will get no result ??   ???
The Tone God
Quote from: modmod on February 07, 2007, 10:56:51 AM
My guess would be the search engine does not like the "-" as it is a special character.
Andrew
