Russian npn germanium transistors GT311
Started by Meanderthal, February 11, 2007, 05:25:45 PM
bluesdevil
That would be looking from the top, sorry.
"I like the box caps because when I'm done populating the board it looks like a little city....and I'm the Mayor!" - armdnrdy
MetalGod
thanks, I'll see if I can get them to bias up with this new pinout  :-\
Pete: With the ground leg facing you, the pinout should be BCE, if you have the same ones.
  How are you ID'ing the ground leg ?
  Mine have the little black dot nearest one outside leg, and the legs exit the body and form an arrow shape [the middle lead is offset].
  With the transistor standing' in front of me, and the offset lead facing me [ie the 'arrow' pointing toward me...
MetalGod
Ok, I managed to get a spec sheet from the guy on ebay I bought them off...
bluesdevil
MetalGod
Quote from: bluesdevil on July 25, 2007, 05:37:58 PM
Damn, I just uploaded a labeled pic. Here it is anyway:
http://aronnelson.com/gallery/album129/GT311
hey, thanks for that anyway - appreciate the effort.
fwiw, that's the pinout I worked out using the diode tester on my DMM but couldn't get it to bias up - still can't with any pinout   ???
