How to check the DC voltage on the output of your effects devices?
Started by ulysses, February 12, 2007, 05:48:51 PM
ulysses
Hey guys
can someone point me in the right direction to find out how to check the DC voltage on the output of my effects devices?
maybe a docco exists or a breif explation on where to put the multimeter pins would be appreciated :)
cheers
ulysses
zyxwyvu
Just set your multimeter to measure DC around a few volts, and put it between ground and the output signal. You can do this inside the enclosure, or you can just take a cable, plug it into the output jack, and measure the voltage across the tip and sleeve of the end of the cable.
GibsonGM
It's a good practice to get into...you'd be surprised what you can sometimes find if you've shorted your output cap, ha ha...   ;)
ulysses
