Am I blind... (ring mod q)
Started by JimRayden, February 24, 2007, 05:39:05 PM
JimRayden
...or there's no "trannies+diodes+AFO" ring modulator schemos for guitar use around here?
Jimbo
JimRayden
Hmm, I just thought of using the Atari Punk Console as the carrier signal...
I now know what my next project is. ;)
Jimbo
$uperpuma
oldrocker
I'm not sure this is what you want but I found this.  It's Jens HF modulator.  I've been wanting to bread board this one and try it myself.  I was told by someone that any modulation effect can be turned into a ring modulator fairly easy.  So I would assume you could make a tremolo into a RM I suspect. The John Hollis Zombie Chorus is what I use mostly.  It has a nice easy mod to a toggle switch for ring mod effect.
http://www.schematicheaven.com/effects/ggg_jen_hf_modulator.pdf
calculating_infinity
I remember tcobretti posted something about using an ad633 and using the apc for the carrier signal.  I still need to get around to that...
choklitlove
Quote from: oldrocker on February 24, 2007, 06:59:10 PM
yeah, GGG has an entire project for that.  here: http://generalguitargadgets.com/pdf/ggg_jen_hf_mod.pdf
i've made the board, just got to finish it.
my band.                    my DIY page.                    my solo music.
