solder pots, not potentiometers, but solder pots?
Started by JisforJustin, March 14, 2007, 10:18:49 AM
JisforJustin
Like these:
http://www.jameco.com/webapp/wcs/stores/servlet/CategoryDisplay?storeId=10001&catalogId=10001&langId=-1&categoryId=602060
Has anyone used them?
This guy on Ebay is selling a tool for dipping your circuits into solder pots:
http://cgi.ebay.com/SOLDER-POT-CIRCUIT-HOLDING-TOOL-SOLDERING-TOOL_W0QQitemZ7588490497QQcategoryZ71394QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
So I assume that you wire up your board and put all your components in and dip your board into the solder pot and voila you have a soldered board. Has anyone used this kind of setup before?
JisforJustin
OK one use for solder pots would be pre-tinning a whole bunch of wire all at the same time:
Copper wires are usually tinned by dipping them into flux (view A of figure 2-25) and then into a solder bath (pot) (view B of the figure).
http://tpub.com/neets/book4/12i.htm
OR for dip soldering...
Here is a partially automated way to dip solder PCBs, everyone needs one:
http://www.apsgold.com/pdf_public/Bdipper.pdf
Here is a good overview of what solder pots are all about:
http://www.americanbeautytools.com/bulletins.php?cat=9
Shoot, I bet you could get a small wave-solder machine pretty cheap. You're going to need one soon anyway, right?
jonathan perez
why not just solder the good yet to fail old fashioned way?
pjwhite
Solder pots are also really useful for unsoldering parts from PCBs.  You can grab an IC on a board with a pair of pliers, float the board on the solder pot for a couple of seconds, and pull the IC right out of the board.
JisforJustin
Nice, that would be handy.
Anyone ever done any dip soldering?
