Orange Sunshine ridiculously gated
Started by black mariah, March 21, 2007, 04:26:26 AM
black mariah
Long story short I built an Orange Sunshine. Plug it in, whack the strings, and it goes *BLAPT* and cuts off. Okay, fine, misbiased. I change the 10K resistor out with a 33k resistor. Plug it in, whack the strings, and it goes *blpt*. How can it be WORSE? I plug my LPB into the front of it to see how bad it really is and I have to play damned hard to get it to make noise.
Something's really wrong and I don't know why. I'm getting about .6v to the collector of Q1. Everything is hooked up fine. I reflowed all the connections and everything. Checked, rechecked, and re-rechecked the wiring. It's all correct.
But it goes *blpt*
*grumble*
I'm using 2N2222's, BTW.
lenwood
Try this and post your readings:
Debugging thread
http://www.diystompboxes.com/smfforum/index.php?topic=29816.0
What is the collector voltage at Q2?
Lennie
black mariah
Q1 and Q2 have about the same readings. There's .6 collector, 0 base, and 0 emitter.
Sir H C
nightingale
be well,
ryanS
www.moccasinmusic.com
black mariah
Quote from: Sir H C on March 21, 2007, 09:28:10 AM
0 on the bases is way off.
No kidding. So what causes that? My first thought was something is grounded where it shouldn't be, but that's just not the case here. :icon_sad:
Quote from: nightingale on March 21, 2007, 10:23:34 AM
what layout are you using?
The perf layout in the gallery. http://aronnelson.com/gallery/albums/album151/ORANGE_SUNSHINE_FUZZ_PERFBOARD_001.gif
Torchy
Left hand side of R3 goes nowhere ... should be Vcc ?
Sir H C
Quote from: Torchy on March 21, 2007, 04:02:47 PM
Yep and that would keep the bases at 0 volts.
Pretty much it is a fuzz face without any controls.  Cool pedal, cool sound, very zen.
black mariah
Quote from: Sir H C on March 21, 2007, 04:04:12 PM
But what about the .6v at the collector? ??? That's what has me stumped.  :icon_question: :icon_neutral:
petemoore
  May work better with low gain Si ?
  2n2222 or whatever measures under 100hfe or so...
  Long story short?... from vague memory of Orange Sunshine experiences, and reads
black mariah
Quote from: petemoore on March 21, 2007, 06:27:04 PM
Huh? ???
RLBJR65
Yep R3 is just hanging open it should go to V+
It's an easy fix just connect R3 to R2 @ V+.
Hate to be preachy but... the search button is your friend :icon_wink: http://www.diystompboxes.com/smfforum/index.php?topic=54526.0
I took the corrected layout down, guess Andrew never got around to changing it.
Richard Boop
black mariah
Quote from: RLBJR65 on March 22, 2007, 07:20:59 AM
That's the way I had it. I always cross-reference schematics and layouts to avoid such screwups. :icon_wink:
