Building a NE572 compressor..
Started by dschwartz, March 21, 2007, 06:06:41 PM
dschwartz
I have a NE572 and a 571 in my IC stock, i bought them hoping to make a simple, ordinary, basic compressor out of them, but i just cant find a single circuit based on those IC´s..
YES..i searched the forum, but i couldn´t get anything usable...just some thoughts and ideas..
the datasheets for this chips are very vague, or i didnt really understood how to make a usable compressor with it...
does anyone have a schematic, pcb or anything based on this chips? i´m thinking a copressor, but any circuit will do...i just want to feel that buying those chips was a good idea.... :icon_rolleyes:
thanks!!!
Tubes are overrated!!
http://www.simplifieramp.com
Jaicen_solo
Check out the Rocktage on Generalguitargadgets.com, that uses an NE570 as a Compander.
StephenGiles
#2
Home & Studio Recording had a 572 compressor article - I remember that edition had a pale blue cover and in August '83 Polyphony: The Penultimate Compressor. I have seen another compressor circuit using that chip, maybe Rane or Symetrix.
Arn C.
I could not find the "rocktage" on GGG.  Where is it?
Arn C.
StephenGiles
George Giblet
#5
One of the magazines used an adaptation of the philips application note:
  http://www.nxp.com/acrobat_download/applicationnotes/AN174.pdf
See figure 12, page 5 - note this is a had limiter.   IMHO it's not that great.
The app note has a fixed threshold but the magazine article made the threshold adjustable.
I don't remember seeing the magazine version Stephen Giles mentioned.
I have the POLYPHONY NE572 project article in question, and may even have a scan of it.  It's a pretty deluxe unit by many standards, using frequency splitting and dual-band compression, which should produce a more transparent sound.  Unfortunately, while there is a schematic, there is no layout.
dschwartz
well that woulk be great! ... i can redraw the schematic on expressPCB and make a board and layout...is the information what´s important...
PD: on the few circuits i found, i noticed that non of them had control for attack or decay or threshold or any....the circuit for a compressor is there, its just that i want to know how to control those parameters....
The NE570/571 uses a single cap on pins 1 and 16 to provide the time constants.  Unfortunately, unless one shifts to a substantially more complex support circuitry, this does not permit an easy differentiation between attack and recovery, merely a global "How do ya want it?  Faster or slower?".  The NE572 improved upon this by permitting separate attack and recovery cap selection on pins 4/12 (attack) and 2/14 (recovery).  I suppose it is possible to either implement step-wise variable attack and recovery using a switched set of cap values, or to implement  a continuously variable recovery using a variable discharge resistance in parallel with the recovery cap.
dschwartz
thats very good information!!!! thanks!!!!!
StephenGiles
Quote from: Mark Hammer on March 22, 2007, 12:15:13 PM
The H & SR design tried to get over this problem, I'll try to find it.
If I remember correctly, separate A and R times were attainable with an NE570, except that it would take an extra 4 op-amps or something like that to do it.  At that point, the 570 stops being a one-chip solution and turns into something on par with a completely discrete solution.
dschwartz
well i have a ne572, so. i can use that cap/pot parallel solution.. sounds good to me.. thanks!
StephenGiles
StephenGiles
