PT80 - Function of 47uF across pins 2/3 of PT2399
Started by bdevlin, March 21, 2007, 06:14:27 PM
bdevlin
I have a testy unit.  Looking at the components I see my 47uF cap looks black on top.  Haven't tested it yet but I am hoping someone can tell me what purpose it serves.
bioroids
It is supposed to be the bypass capacitor for the 2.5v reference voltage I understand (to avoid AC fluctuations on the reference voltage). I don't think the IC can work fine with that cap damaged.
Luck!
Miguel
Eramos tan pobres!
dschwartz
just for learning....
that means that this capacitor sends to ground any AC component ind the 2.5 supply?
Tubes are overrated!!
http://www.simplifieramp.com
igor12
"this capacitor sends to ground any AC component ind the 2.5 supply"
Yes, I believe so, although the primary source of AC noise is the clock on board the PT2399.
bioroids
And also that is the reference used in the internal opamps, so the audio is bypassed by this capacitor too (just like the capacitor in the 4.5v voltage reference on the standard opamp circuit).
Luck!
Miguel
Eramos tan pobres!
