Fuzz Face bias calculator software updated, now in html version.
Started by mac, March 31, 2007, 03:47:28 AM
mac
Due to compatibility reasons when compiling the app for windows and mac os, I decided to code it in html format using javascript. I tested this version on macs and pc and it seems to work fine. Go here:
http://geocities.com/guitarfxs/exes/biascalculator.zip
Unzip the file. The hmtl version is inside the folder "bias html folder", do not modify or move its content. Double click the file main.html. The mac and pc apps are also included. Note that the apps do not check what you type, and if you get strange results swap the decimal separator "." <-> ",".
Variables are very sensible to small changes in hfe, leakage and Vbe. I also assumed a fixed Vbe. Use it to estimate resistors and voltages.
mac
