Building a Speaker Cabinet...
Started by DanielWong, April 09, 2007, 09:08:35 PM
DanielWong
pretty much, what tool can I use to cut speakers in cabinets?
John Lyons
The simplest tool to use is a Jigsaw.
A more complex tool is a router with a hole template.
The Jig saw will work fine you are going to use grill cloth to cover the hole.
If you need a nice clean hole the router and template is best.
John
Basic Audio Pedals
www.basicaudio.net/
DanielWong
Paul Marossy
I used only a jigsaw and a drill to make my latest DIY speaker cabinet a couple of weeks ago.
  I used a drill to start the router.
  Just inside where the router hole line is.
  I used a zenith console plate with beveled edges [nice cause it rides right over and catches], three little holes and the router has the plate mounted on it, the fourth hole is made exactly...er...figured as 1/2 the hole width...taking into account that you want to measure from the outside of the cutting blade.
  Straight cutter bit [3/8'' IIRC], with a first, shallow pass, then the final cut [if the blade cutter is less deep than the wood] through.
  Then I used a roundover bit w/bearing on the end.
  Perfect hole [just a teeny 'fudge' where entry/exit was made...].
  I never had as good results with a jigsaw.
