Quick question about TS wiring
Started by rankine, April 11, 2007, 01:17:41 PM
rankine
I've started making my Tubescreamer from Torchy's layout but I don't understand the off-board wiring. It says on the diagram 'LED+'. Does this mean that the layout is for a 3p3t switch with true bypass and LED indicator, or is there a way I can connect this vero to a dpdt true bypass without the LED indicator?
Barcode80
if you want to use a dpdt, then yes you can just omit the LED and wire everything else normally as indicated.
