Did I fry my ge transistor?
Started by Bucksears, April 13, 2007, 10:59:28 PM
Bucksears
I finished up my GGG '69 Fuzz Face (neg. ground) tonight and it had no sound at all. After checking it over again, I had Q2 in backwards.
It was on for all of 5min.; is it possible that I fried it?
I haven't had an opportunity to try it out correctly due to the late hour tonight.
Thanks,
- Buck
reverberation66
   seems like it should be fine, I think some of these fuzz circuits will still work even with the transistors in backwards.
darron
Quote from: reverberation66 on April 14, 2007, 12:12:33 AM
yeah. i don't think that will damage it. i've even shorted positive and negative together accidentally over night with a battery in it. worked fine still, thought the 1000uf capacitor i used to prevent motorboating nearly exploded out of it's case! i guess most of the heat got burnt off in there and expanded it. probing it incorrectly in my dmm hasn't damaged the transistors either. they were ac128's
zjokka
like this?
http://www.muzique.com/lab/reverse.htm
QuoteI finished up my GGG '69 Fuzz Face (neg. ground) tonight and it had no sound at all. After checking it over again, I had Q2 in backwards. It was on for all of 5min.; is it possible that I fried it?
Is it possible? Yes.
Is it likely? No.
Germanium devices are sometimes more robust about being reversed than silicon, at least the devices made before planar processing. A very few of those older devices are actually symmetrical - the base-emitter and collector base junctions are almost alike.
Try it. Likely you'll be fine.
  I somehow ended up with some SB transistors [so, good'], which are fried, at the time I was building and tweeking TB's FF's and RM's.
  For my initial tests, after battery non-shorting test, I'd pop in some 2n3906 or other ROTM PNP, until I got some sound and nothing way out of whack voltage wise, then apply the GE's.
  Then I'd test transistors in the DMM"s hfe sockets, or just put them in a known working circuit.
