Adapters
Started by rhdwave, April 19, 2007, 01:36:15 PM
Ben N
Quote from: ponq on April 21, 2007, 02:31:11 PM
1-spot does handle multiple boxes, even line6 boxes. The problem is the Echo Park. It cannot be used with a daisy chain. I've had several EP's and several daisy chains and always had this issue. In the end you have to feed the EP seperately (or sell it, as I did ;) )
Actually, I find the EP to be reasonably ok with the daisy chain. It only went south when I added the SC. I haven't tried the SC with the daisy chain without the EP because I don't use chorus as much as delay.
