Powering 9v pedal question Newbe
Started by msurdin, April 28, 2007, 03:38:16 AM
msurdin
I am wondering If I dont want to use a battery clip and there are no jacks....just pedal to pedal and so on. I just want to wire the pedal straight the one of the 9v supplies of of GGG or any of them, How can I wire it. How would I go about this?
Thanks a bunch!
mattpocket
use the tonepad offboard wiring diagram and omit the battery snap, as far as having no jacks goes you will need to connect the wires from the output of one pedal to the input of the next pedal... and where your earths are connected to the sleeve of the inputs you will just have to connect all these together at the main input (I am guessing you'll have an input and output at the end of this effects line!)
Hope that helps,
Matt
Built: LofoMofo, Dist+, Active AB Box, GGG 4 Channel Mixer, ROG Omega
On the Bench:Random Number Generator, ROG Multi-face, Speak & Spell
My Pop-Punk Band - www.myspace.com/stashpocket
