Solid core wires, not so good!
Started by momo, April 29, 2007, 01:45:30 PM
calculating_infinity
Quote from: Barcode80 on April 30, 2007, 12:33:54 PM
Quote from: kvb on April 30, 2007, 11:38:04 AM
pre-tinned means that the strands are already fused together.  Instead of stripping stranded wire and then putting a bit of solder on the end to keep the strands from fraying (impossible to stick through a pcb hole), the wire acts like solid core but is way more forgiving when it comes to movement.
That's why I mentioned the cardboard. Not as complicated as MetalGod's pic. I just meant support and pick up the circuit, all the knobs, (the battery is the real prob - heavy with thin leads), etc with a shoebox lid or something and there will be far less movement to worry about.
i've always just twisted the ends to put stranded through a pcb, is that not acceptable practice?
I think people tin the wire with solder to avoid finger grease, im not sure what else.
newbie builder
Quote from: MetalGod on April 30, 2007, 12:13:21 PM
Quote from: mattpocket on April 30, 2007, 06:21:47 AM
Thats crazy what is it?
started out as a fuzz face,
;D
I've built a fuzz face. THAT is not a fuzz face....that's a monster....it's beautiful :)
I find difficult and not fun is having to hold the board,hold the soldering iron, hold the solder and put all that toghether on a 5 millimeter area without shorting around.(Parkinsons and DIY I guess dont match)
So if I could eliminate holding the solder lead, because there is already a bit on the wire, then that would be great, tack it on and then I would have a hand free to complete the soldering.
  I have a free left hand, w/ergonomically placed hand rest, this allows very precise tip to board approach and retreats easily from any angle. I have the iron mounted in a box, tip at a slight down angle, under the exhaust tube and surrounded by lighting w/ close in light on gooseneck, The palm rest makes it easy to keep my hand steady and control the board w/fingertips [instead of an iron w/ 6'' between fingers and work area], this improved speed and the boards look great, I haven't dropped the iron since I built it, but I do have to take it out for some in-box work.
