sweep for midrange
Started by duclon, May 21, 2007, 12:34:07 PM
duclon
I've been building some tone stacks, passive and active for a couple boxes i have.
question: does anyone have a tone stack or part of a tone stack schematic that has a sweep or adjustable frequency for one on the frequency's. i want to make my midrange tone pot frequency variable with another pot.
thanks
Mike
Adventure_Audio
Ive been trying to find something like this for a while and cannot seem to figure it out. Best bet is to rock an active EQ to sweep a controlled section of the mids
blackieNYC
http://geofex.com
The simple parametric Eq. I just built a single midrange band.  It's great.  Fixed-wah boost sound or a very narrow Q notch.  Adjust Q, freq, and gain.   See the sabrotone version of it as well.
mth5044
merlinb
Brdiged differentiator?
http://books.google.co.uk/books?id=9kMDBAAAQBAJ&lpg=PP1&dq=merlin%20blencowe&pg=PA200#v=onepage&q&f=false
Or use a regular TMB tone stack but add a variable resistor in series with the slope resistor.
Processaurus
I've had a back burner project for a while to make a little PCB of the Metal Zone EQ section to add parametric mids to fuzzes, etc:
The parametric mid control (note the weird pots, both are dual gang, one is "C" taper, one is "G" taper (???)) begins at C011 and ends at C005.
State variable as a bandpass, providing boost/cut by providing the feedback around an opamp. You get one knob (albeit a dual pot) control of frequency, one knob control of Q, and one knob control of boost/cut. It's what's used in many early studio parametrics.
mth5044
Quote from: Processaurus on September 09, 2014, 03:09:39 PM
From what I understand, G taper is used in some EQ situations. According to Rob Strand:
"The G taper is a symetrical taper with 50% resistance at 50% rotation, ~10% resistance at 30% rotation and ~90% resistance at 70% rotation. "
