Help my first build isnt working!
Started by DBDbadreligion, May 21, 2007, 06:42:02 PM
DBDbadreligion
it is the B.Blender.
it bypasses and a clean signal goes through when it is off, but when it is on the volume knob goes buzzzzz when i turn it up.
http://s5.photobucket.com/albums/y178/DBDbadreligion/?action=view&current=B-1.jpg
that's the schematic i went from, is it wired correctly?
thanks,  nick
Nick Landt
DBDbadreligion@gmail.com
rubix cube
I can't really tell how your input jack is connecting the rest of the circuit to GND from the picture.   (?)
Buzzing has meant something isn't connected to ground on many occassions for me, so that'd be the first thing I'd check.
Then probably the voltages around the board with a multimeter.  Good luck!
DBDbadreligion
the input is connected from the tip of the input to the left-middle row lug
Nick Landt
rubix cube
Okay! My brain just told me it was a red wire so it was 9V! Have you got a link to the schematic?
DBDbadreligion
Nick Landt
DBDbadreligion
i also want to mention, that i grounded all the grounds to a screw that i screwed in the enclosure.  the aluminum lid of the enclosure would not let solder stick to it, neither the pots would.  so i may have a ground issue.
Nick Landt
DBDbadreligion
and also the led is working, so i dont think it is a 9v error.
Nick Landt
DBDbadreligion
i just checked the 9v, with a voltmeter.  it's getting over +8.  and all the IC's are getting power.
Nick Landt
DBDbadreligion
on the IC's the 3rd pin is not getting a reading on either of the IC's.
Nick Landt
DBDbadreligion
Nick Landt
rockgardenlove
Er, get a schematic, and recheck all the switching, board wiring, and stuff like that.
gaussmarkov
in order to help you debug your circuit, we will need some information from you.  the forum has developed a method for this and it is described on the Debugging Page.  basically, we will need voltage readings on all of the pins of your ICs, 1 through 8, and we need you to build an audio probe and to trace the audio signal through your build.  but don't take my summary as the whole story--read the whole Debugging Page and follow the instructions on reporting your findings.  once you have done that, i am sure that we can make some progress on your build.  you chose a good one for your first.
all the best, gm
DBDbadreligion
alright kool, i will get into to all of that tomorrow.
Nick Landt
ambulancevoice
can you take a picture of the pcb board (both sides)
and check that all the electrolytic caps are the right way around
mattpocket
Quote from: DBDbadreligion on May 21, 2007, 07:39:19 PM
Did you connect the sleeve of the input jack to sleeve of the output jack?
For ground, we normally send all the grounds to the input jack sleeve, and then connect the input jack sleeve to the output jack sleeve. If you are using open metal jacks, and a metal enclosure, then you wont need to connect the input and output sleeve together, as this connection will be made through the enclosure.
I've never heard of anyone doing it with a screw into the enclosure, although I understand your logic... Also, if you ground something twice, sometimes that can cause problems. I.e. having a connection through the enclosure between input/output jacks, and also having all the grounds connected to the enclosure. Sometimes, you forget that the connection is made without wires.
Hope some of that helps. Look at tonepad's off board wiring diagram for grounding techniques as described above.
Matt
Built: LofoMofo, Dist+, Active AB Box, GGG 4 Channel Mixer, ROG Omega
On the Bench:Random Number Generator, ROG Multi-face, Speak & Spell
My Pop-Punk Band - www.myspace.com/stashpocket
rubix cube
Are you getting around 4.5V at the junction of R2 and R3?
DBDbadreligion
Quote from: mattpocket on May 22, 2007, 02:59:01 AM
Matt
ok i will try this, i have not grounded it like that i just put all the grounds on the screw because i dont have a metal enclosure.
Nick Landt
mattpocket
If you dont have a metal enclosure, then connect all the grounds to the input sleeve and then connect the sleeve of the input jack to the sleeve of the output jack.
Matt
DBDbadreligion
alright cool, could this possibly fix it?
Nick Landt
GibsonGM
Step 1 - please post all your voltages like in the Debugging Page  ;)
While you're in there doing that, test that the grounding screw you're using does in fact make electrical contact with the enclosure and ground (battery - terminal) when a plug is inserted into the input jack.  Use a DMM, no battery, patch cord plugged into input, and check from that screw to the - terminal of the battery clip (the 'male' part).  You should get a beep on the continuity setting.  Sometimes the contact isn't good, which will do what you're describing...
8)
