Sunn Buzz troubles
Started by rockgardenlove, May 22, 2007, 08:36:22 PM
rockgardenlove
I tried using these transistors: 2n5089, 2n3904, and 2n2222.
The signal stops at the base of Q2, that is unless I strum REALLY hard and then I get a sharp crackle through.
Must be a mis-bias, huh?
What should I do?
Barcode80
replace all the supply resistors with 25k pots, bias to 1/2 voltage as a starting point.
burnt fingers
How are you powering it.  It looks like the schem calls for a single AA battery at 1.5 volts.  You probably would run into issues pumping 9v through it if it.
Scott
Rock and Roll does not take a vacation!!
www.rockguitarlife.com
My Music
Barcode80
rockgardenlove
Bad solder joint.  :)
I was also using 9v, I'm so used to it, didn't even think about using an AA at all.
Sounds great now, nifty circuit.  I have a much bigger output cap on for now, sounds a bit Muffish.  Niiiiice.
It's gonna be a pain to power from 1.5 volts though, unless I work out a way to hold an AAA inside.  I don't think an AA will fit with my stupid box drilling.
Anyways, all for the better, because my piece of perfboard was rather packed.
Cheers!
