Older Small Stone Osc bleed through while Bypassed.
Started by Jamforthelamb, May 25, 2007, 10:54:05 AM
Jamforthelamb
Hey Everyone,
I have an older Small Stone that I recently bought off ebay (was inop). I got it up and running again, (re-flowed some solder and voila') and converted it to true bypass. My problem is just as it states in the subject line. When I have it in bypass I can hear a high pitch whine that cycles with the osc of the circuit (really noticable with the depth switch on). What's my best solution for this ? I have it wired for the standard TB with a 3pdt (might add an LED later), should I wire it so the input of the effect is grouded when bypassed ? I haven't replaced the electo's yet (no 33ufs on hand) would that help ?
Thanks,
JFTL
R O Tiree
Grounding the input would be my first port of call, yes.  Try initially just touching with a piece of wire from the input pad to the ground rail, before you go de-soldering your switch.  I'd have thought that the 470k pull-down resistor (shown on the Issue J schem at http://www.schematicheaven.com/effects/eh_smallstonephaser.pdf) should already do this, however.
I don't think that replacing the caps would do anything for this oscillation noise, but it's worth doing in any case in old FX.
After that, have a look at your lead dress.  Usually, this seems only to be critical with high-gain circuits, but you never know...
...you fritter and waste the hours in an off-hand way...
SonicVI
Mine did that as well, even after I added a DPDT switch. It only happened with the color switch in the up position. I believe I remedied it by soldering a small value cap between ground and somewhere on the PCB, the input wire joint I think.
