4PDT Stomp Switches
Started by smallbearelec, May 29, 2007, 02:48:22 PM
smallbearelec
I apologize for all the past false hopes and blown expectations. It took the manufacturer a long time to get the machining all straight.  However, I do now have these on the shelf in decent quantity, my SKU 0200A, $12.00 in small lots.
SD
rockgardenlove
Awesome!
Though personally, I must admit I'm waiting for the Alpha 9mm ZVex style pots.   8)
mattpocket
Can someone say what kind of things we'll be using these for?
Matt
Built: LofoMofo, Dist+, Active AB Box, GGG 4 Channel Mixer, ROG Omega
On the Bench:Random Number Generator, ROG Multi-face, Speak & Spell
My Pop-Punk Band - www.myspace.com/stashpocket
the recluse
I have a stereo tremolo build that I could use one of these to do true-bypass on both inputs.  I believe another common application would be to use it for on/off switching with multiple status LEDs.
Pushtone
Quote from: mattpocket on May 29, 2007, 03:04:12 PM
Matt
Stereo bypass
Barcode80
also as a master bypass for dual effect boxes.
dmk
resistance is futile...
...if <1Ω
B_of_H
All I want to know is when the 5pdt footswitch is coming out.   :icon_wink:
These can also be used for order switching in a dual-function pedal.  For example, swapping the order of a fuzz and wah in a fuzz-wah pedal, or phaser and fuzz in a fuzz-phaser pedal.  They can also be used for switching the cap values in a phaser to "Univibe" it.
mattpocket
swapping four caps for four different caps?
Matt
rogerinIowa
finally I can toggle between Dyna and Rosscomp modes with my foot!
friends dont let friends use stock pedals.
Paul Perry (Frostwave)
Can't remember how many caps change when you 'univibe' something.. but this could handle it :icon_wink:
mattpocket
Think I will have to wait for someone to make a little layout or drawing of how it would work before I understand it properly...
Matt
Brett Sinclair
Quote from: rogerinIowa on May 29, 2007, 09:16:47 PM
I asked about the necessity of a 4PDT before (http://www.diystompboxes.com/smfforum/index.php?topic=57426.msg445839)... why can't you simply break the connection with the caps and ground?
runmikeyrun
Quote from: B_of_H on May 29, 2007, 05:06:02 PM
well steve you KNEW that request was going to come next, right??
I say, bring it on!
Bassist for Foul Spirits
Instagram: @torcheffects
Dislikes: old women
To all those who rub their hands with glee about such matters, I offer the following advice: MAKE SURE YOU LET THE SWITCH COOL OFF BETWEEN EACH SOLDER JOINT!!
I've found that the dab of grease the manufacturer puts in to temporarily hold the rocker contact in place during assembly can liquify when there is too much heat buildup.  When it liquifies it tends to flow along the contact and completely coat it, leading to switch failure.  You CAN disassemble the switch and wipe the flowed grease off, but it is a PITA, and I imagine all the moreso with a 4PDT.  So, get in and get out quickly when you solder, and don't give heat a chance to build up.  I am quite confident that the build quality on these switches is as good as any.  We don't need heat-precipitated switch failure turning into rumours turning into accepted wisdom.  Use them properly and they should delight you for years of unfailing service.
ulysses
Quote from: Paul Perry (Frostwave) on May 29, 2007, 10:08:49 PM
at least 3, maybe 4 depending on the caps you choose..
cheers
ulysses
Jamforthelamb
Awesome!
Now I will be able to build my Podxt/analog pedalboard A/B switcher with indicating LEDs!
Hmm....I wonder if I can make one fit in my Small Stone... :icon_smile:
JFTL
MikeH
Another thing these can be handy for is creating a faux 2-channel distortion, a la plexitube and the like.  For instance in a tube screamer you can switch the resistor that sets the gain, a different volume pot for the "lead volume", maybe a little fatter, or a little sharper..., one for the LED... and voila.  A 2 channel on the fly tube screamer with lead and rhythm channels.  The possibilities are endless... or 4, depending on how you look at it.
mattpocket
Oh, I think I would be able to build an amp channel and effect loop switcher with one switch! Oooh! Cool!
